[GRASS-QA] GRASS QA: brad | ./grass6/lib/btree/update.c |no clones | 0 monsters | 0 warnings
Thu Oct 12 05:27:17 EDT 2006
Hello brad,
ANALYSIS
lib/btree/update.c functions
btree_update (Begins at: 7 Ends at: 78)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       8 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
store (Begins at: 80 Ends at: 92)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
