[GRASS-QA] GRASS QA: brad | ./grass6/lib/btree/next.c |no clones | 0 monsters | 0 warnings
Thu Oct 12 05:27:17 EDT 2006
Hello brad,
ANALYSIS
lib/btree/next.c functions
btree_next (Begins at: 3 Ends at: 31)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
