[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.in.ascii/points.c
|no clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 14 02:53:36 EDT 2006
Hello hamish,
ANALYSIS
vector/v.in.ascii/points.c functions
is_int (Begins at: 12 Ends at: 22)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 11 | | OK |
metrics are OK
is_double (Begins at: 26 Ends at: 51)
Complexity: | 6 | | OK |
LOC: | 26 | | OK |
metrics are OK
points_analyse (Begins at: 53 Ends at: 207)
Complexity: | 19 | * | |
ParamNBR: | 11 | *** | MONSTER |
CalledNBR: | 39 | * | |
LOC: | 155 | * | |
1 metric are OUT OF RANGE!
points_to_bin (Begins at: 209 Ends at: 332)
Complexity: | 14 | | OK |
ParamNBR: | 13 | *** | MONSTER |
CalledNBR: | 51 | * | |
LOC: | 124 | * | |
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
