[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.in.ascii/points.c
|no clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 14 05:37:34 EDT 2006
Hello hamish,
ANALYSIS
vector/v.in.ascii/points.c functions
is_int (Begins at: 13 Ends at: 23)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 11 | | OK |
metrics are OK
is_double (Begins at: 27 Ends at: 52)
Complexity: | 6 | | OK |
LOC: | 26 | | OK |
metrics are OK
points_analyse (Begins at: 54 Ends at: 259)
Complexity: | 32 | ** | Warning |
ParamNBR: | 12 | *** | MONSTER |
CalledNBR: | 51 | * | |
LOC: | 206 | ** | Warning |
1 metric are OUT OF RANGE!
points_to_bin (Begins at: 261 Ends at: 385)
Complexity: | 14 | | OK |
ParamNBR: | 13 | *** | MONSTER |
CalledNBR: | 54 | * | |
LOC: | 125 | * | |
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
