[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.in.ascii/head.c |no clones | 0 monsters | 0 warnings
Sat Oct 14 05:54:50 EDT 2006
Hello hamish,
ANALYSIS
vector/v.in.ascii/head.c functions
read_head (Begins at: 9 Ends at: 58)
Complexity:   |      18 |     * |         |
CalledNBR:    |      33 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
