[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.coin/cmd_parms.c |no clones | 0 monsters | 0 warnings
Sat Oct 14 13:06:59 EDT 2006
Hello jachym,
ANALYSIS
raster/r.coin/cmd_parms.c functions
command_version (Begins at: 26 Ends at: 102)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      77 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
