[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.colors/main.c |1 clones ( main.c )| 2 monsters | 0 warnings
Sat Oct 14 13:13:57 EDT 2006
Hello jachym,
ANALYSIS
raster/r.colors/main.c functions
rules_files (Begins at: 34 Ends at: 77)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      44 |       |      OK |
metrics are OK
cmp_names (Begins at: 79 Ends at: 85)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
list_rules_files (Begins at: 87 Ends at: 131)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      45 |       |      OK |
metrics are OK
main (Begins at: 133 Ends at: 359)
Complexity:   |      40 |   *** | MONSTER |
CalledNBR:    |     108 |   *** | MONSTER |
LOC:          |     227 |    ** | Warning |
2 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
  cmp_names
In raster/r.colors/main.c clones of  cmp_names are:
	lib/gis/datum.c  compare_table_names
Threshold GRASS6 key metrics values at 2006-10-14 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
