[GRASS-QA] GRASS QA: hamish | ./grass6/raster3d/r3.to.rast/main.c |no clones | 0 monsters | 2 warnings
Mon Oct 16 03:38:44 EDT 2006
Hello hamish,
ANALYSIS
raster3d/r3.to.rast/main.c functions
fatal_error (Begins at: 48 Ends at: 66)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
set_params (Begins at: 71 Ends at: 97)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
g3d_to_raster (Begins at: 102 Ends at: 172)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      71 |       |      OK |
metrics are OK
open_output_map (Begins at: 177 Ends at: 186)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
close_output_map (Begins at: 191 Ends at: 195)
ParamNBR:     |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
main (Begins at: 200 Ends at: 394)
Complexity:   |      22 |     * |         |
CalledNBR:    |      76 |    ** | Warning |
LOC:          |     195 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-16 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
