[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.in.ascii/main.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Oct 16 08:35:46 EDT 2006
Hello hamish,
ANALYSIS
raster/r.in.ascii/main.c functions
main (Begins at: 18 Ends at: 254)
Complexity: | 26 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 100 | *** | MONSTER |
LOC: | 237 | ** | Warning |
1 metric are OUT OF RANGE!
file_cpy (Begins at: 257 Ends at: 285)
Complexity: | 5 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 29 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-16 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
