[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.le/r.le.patch/input.c |no clones | 3 monsters | 0 warnings
Tue Oct 17 14:22:20 EDT 2006
Hello markus,
ANALYSIS
raster/r.le/r.le.patch/input.c functions
user_input (Begins at: 32 Ends at: 547)
Complexity:   |      81 |   *** | MONSTER |
CalledNBR:    |     184 |   *** | MONSTER |
LOC:          |     516 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-17 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
