[GRASS-QA] GRASS QA: markus |
./grass6/raster/r.le/r.le.patch/main.c |no clones | 1
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Oct 17 14:22:20 EDT 2006
Hello markus,
ANALYSIS
raster/r.le/r.le.patch/main.c functions
main (Begins at: 36 Ends at: 155)
Complexity: | 60 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 72 | ** | Warning |
LOC: | 120 | * | |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
