[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.le/r.le.trace/user_input.c |no clones | 0 monsters | 0 warnings
Thu Oct 19 03:01:40 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.trace/user_input.c functions
user_input (Begins at: 26 Ends at: 81)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-19 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
