[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.le/r.le.trace/main.c |no clones | 3 monsters | 5 warnings
Thu Oct 19 03:01:39 EDT 2006
Hello hamish,
ANALYSIS
raster/r.le/r.le.trace/main.c functions
main (Begins at: 40 Ends at: 112)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |      73 |       |      OK |
metrics are OK
set_map (Begins at: 114 Ends at: 154)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       9 |       |      OK |
LOC:          |      41 |       |      OK |
at least 1 values are close to an outlier please consider revising code
show_patch (Begins at: 156 Ends at: 274)
Complexity:   |      23 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      48 |     * |         |
LOC:          |     119 |     * |         |
metrics are OK
patch_attr (Begins at: 279 Ends at: 324)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
draw_patch (Begins at: 326 Ends at: 353)
LOC:          |      28 |       |      OK |
metrics are OK
scr_cell (Begins at: 355 Ends at: 368)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
cell_clip_drv (Begins at: 370 Ends at: 489)
CalledNBR:    |      12 |       |      OK |
LOC:          |     120 |     * |         |
metrics are OK
cell_clip (Begins at: 496 Ends at: 717)
Complexity:   |      32 |    ** | Warning |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      37 |     * |         |
LOC:          |     222 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
trace (Begins at: 725 Ends at: 842)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |     118 |     * |         |
metrics are OK
get_bd (Begins at: 844 Ends at: 1503)
Complexity:   |      70 |   *** | MONSTER |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      31 |       |      OK |
LOC:          |     660 |   *** | MONSTER |
3 metric are OUT OF RANGE!
yes_nb (Begins at: 1505 Ends at: 1636)
Complexity:   |      15 |       |      OK |
LOC:          |     132 |     * |         |
clockwise (Begins at: 1638 Ends at: 1646)
Complexity:   |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-19 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
