[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.fill.dir/dopolys.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Oct 19 15:26:48 EDT 2006
Hello jachym,
ANALYSIS
raster/r.fill.dir/dopolys.c functions
recurse_list (Begins at: 6 Ends at: 34)
Complexity: | 7 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 29 | | OK |
metrics are OK
dopolys (Begins at: 40 Ends at: 107)
Complexity: | 6 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 68 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
