[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.fill.dir/main.c |no clones | 1 monsters | 1 warnings
Thu Oct 19 15:26:48 EDT 2006
Hello jachym,
ANALYSIS
raster/r.fill.dir/main.c functions
main (Begins at: 58 Ends at: 293)
Complexity:   |      15 |       |      OK |
CalledNBR:    |     108 |   *** | MONSTER |
LOC:          |     236 |    ** | Warning |
1 metric are OUT OF RANGE!
dir_type (Begins at: 295 Ends at: 334)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |       0 |       |      OK |
LOC:          |      40 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-19 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
