[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.fill.dir/wtrshed.c |no clones | 0 monsters | 1 warnings
Thu Oct 19 15:26:48 EDT 2006
Hello jachym,
ANALYSIS
raster/r.fill.dir/wtrshed.c functions
recurse_cell (Begins at: 12 Ends at: 60)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      16 |       |      OK |
LOC:          |      49 |       |      OK |
at least 1 values are close to an outlier please consider revising code
wtrshed (Begins at: 62 Ends at: 221)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      32 |       |      OK |
LOC:          |     160 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-19 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
