[GRASS-QA] GRASS QA: brad | ./grass6/lib/gmath/brent.c |no clones |
0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Oct 20 05:47:27 EDT 2006
Hello brad,
ANALYSIS
lib/gmath/brent.c functions
brent (Begins at: 53 Ends at: 191)
Complexity: | 12 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 6 | | OK |
LOC: | 139 | * | |
at least 1 values are close to an outlier please consider revising code
brent_iterate (Begins at: 196 Ends at: 235)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 40 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
