[GRASS-QA] GRASS QA: cho | ./grass6/general/g.setproj/main.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Oct 20 23:01:36 EDT 2006
Hello cho,
ANALYSIS
general/g.setproj/main.c functions
main (Begins at: 49 Ends at: 613)
Complexity: | 103 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 247 | *** | MONSTER |
LOC: | 565 | *** | MONSTER |
3 metric are OUT OF RANGE!
min1 (Begins at: 615 Ends at: 620)
Complexity: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 6 | | OK |
metrics are OK
leave (Begins at: 622 Ends at: 624)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 3 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
