[GRASS-QA] GRASS QA: martinl | ./grass6/general/manage/cmd/remove.c |no clones | 0 monsters | 0 warnings
Sat Oct 21 15:29:25 EDT 2006
Hello martinl,
ANALYSIS
general/manage/cmd/remove.c functions
main (Begins at: 9 Ends at: 128)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      39 |     * |         |
LOC:          |     120 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-21 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
