[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.flow/mem.c |no clones | 0 monsters | 0 warnings
Sun Oct 22 05:15:52 EDT 2006
Hello jachym,
ANALYSIS
raster/r.flow/mem.c functions
put_row_seg (Begins at: 34 Ends at: 44)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
initialize_globals (Begins at: 46 Ends at: 68)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
allocate_heap (Begins at: 70 Ends at: 143)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
deallocate_heap (Begins at: 145 Ends at: 176)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-22 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
