[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.flow/precomp.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Oct 22 05:15:52 EDT 2006
Hello jachym,
ANALYSIS
raster/r.flow/precomp.c functions
precompute_tangents (Begins at: 36 Ends at: 44)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
precompute_ew_dists (Begins at: 47 Ends at: 64)
Complexity: | 2 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 18 | | OK |
metrics are OK
precompute_epsilons (Begins at: 67 Ends at: 100)
Complexity: | 4 | | OK |
LOC: | 34 | | OK |
metrics are OK
upslope_correction (Begins at: 103 Ends at: 122)
CalledNBR: | 39 | * | |
LOC: | 20 | | OK |
metrics are OK
interpolate_border (Begins at: 125 Ends at: 144)
CalledNBR: | 144 | *** | MONSTER |
LOC: | 20 | | OK |
1 metric are OUT OF RANGE!
reflect_and_sentinel (Begins at: 147 Ends at: 161)
Complexity: | 3 | | OK |
CalledNBR: | 31 | | OK |
LOC: | 15 | | OK |
metrics are OK
precompute_aspects (Begins at: 164 Ends at: 186)
CalledNBR: | 17 | | OK |
LOC: | 23 | | OK |
metrics are OK
precompute (Begins at: 189 Ends at: 219)
Complexity: | 5 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
