[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.in.arc/gethead.c |2
clones ( gethead.c )| 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Oct 22 05:58:39 EDT 2006
Hello jachym,
ANALYSIS
raster/r.in.arc/gethead.c functions
gethead (Begins at: 15 Ends at: 105)
Complexity: | 17 | * | |
ParamNBR: | 3 | | OK |
CalledNBR: | 29 | | OK |
LOC: | 91 | | OK |
metrics are OK
scan_int (Begins at: 107 Ends at: 121)
Complexity: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 15 | | OK |
metrics are OK
scan_res (Begins at: 123 Ends at: 137)
LOC: | 15 | | OK |
metrics are OK
scan_easting (Begins at: 140 Ends at: 143)
Complexity: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
scan_northing (Begins at: 145 Ends at: 148)
LOC: | 4 | | OK |
metrics are OK
scan_cellsize (Begins at: 150 Ends at: 153)
LOC: | 4 | | OK |
metrics are OK
extract (Begins at: 155 Ends at: 167)
Complexity: | 3 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 5 | | OK |
LOC: | 13 | | OK |
1 metric are OUT OF RANGE!
missing (Begins at: 169 Ends at: 174)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
scan_res scan_int
In raster/r.in.arc/gethead.c clones of scan_res are:
raster/r.in.arc/gethead.c scan_int
In raster/r.in.arc/gethead.c clones of scan_int are:
raster/r.in.arc/gethead.c scan_res
Threshold GRASS6 key metrics values at 2006-10-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
