[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.watershed/ram/main.c |no clones | 0 monsters | 0 warnings
Thu Oct 26 03:39:36 EDT 2006
Hello hamish,
ANALYSIS
raster/r.watershed/ram/main.c functions
main (Begins at: 10 Ends at: 40)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      19 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-26 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
