[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.watershed/ram/sg_factor.c |no clones | 0 monsters | 0 warnings
Thu Oct 26 03:39:36 EDT 2006
Hello hamish,
ANALYSIS
raster/r.watershed/ram/sg_factor.c functions
sg_factor (Begins at: 6 Ends at: 46)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
len_slp_equ (Begins at: 48 Ends at: 67)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-26 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
