[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/find_vect.c |no clones | 0 monsters | 0 warnings
Thu Oct 26 20:56:17 EDT 2006
Hello hamish,
ANALYSIS
lib/gis/find_vect.c functions
G_find_vector (Begins at: 56 Ends at: 75)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
G_find_vector2 (Begins at: 78 Ends at: 82)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-26 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
