[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/opencell.c |no clones | 0 monsters | 1 warnings
Thu Oct 26 23:33:06 EDT 2006
Hello hamish,
ANALYSIS
lib/gis/opencell.c functions
new_fileinfo (Begins at: 113 Ends at: 174)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      62 |       |      OK |
metrics are OK
G_open_cell_old (Begins at: 178 Ends at: 233)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
G__open_cell_old (Begins at: 235 Ends at: 435)
Complexity:   |      22 |     * |         |
CalledNBR:    |      42 |     * |         |
LOC:          |     201 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
G_open_cell_new (Begins at: 461 Ends at: 468)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
G_open_cell_new_random (Begins at: 470 Ends at: 477)
LOC:          |       8 |       |      OK |
metrics are OK
G_open_cell_new_uncompressed (Begins at: 479 Ends at: 486)
LOC:          |       8 |       |      OK |
metrics are OK
G_want_histogram (Begins at: 488 Ends at: 493)
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
G_set_cell_format (Begins at: 496 Ends at: 509)
Complexity:   |       4 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
G_cellvalue_format (Begins at: 511 Ends at: 519)
LOC:          |       9 |       |      OK |
metrics are OK
G_open_fp_cell_new (Begins at: 521 Ends at: 544)
CalledNBR:    |       3 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
G_open_fp_cell_new_uncompressed (Begins at: 547 Ends at: 568)
LOC:          |      22 |       |      OK |
metrics are OK
clean_check_raster_name (Begins at: 571 Ends at: 603)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
G__open_raster_new (Begins at: 606 Ends at: 777)
Complexity:   |      17 |     * |         |
CalledNBR:    |      52 |     * |         |
LOC:          |     172 |     * |         |
metrics are OK
allocate_compress_buf (Begins at: 785 Ends at: 800)
LOC:          |      16 |       |      OK |
metrics are OK
G__reallocate_work_buf (Begins at: 804 Ends at: 818)
LOC:          |      15 |       |      OK |
metrics are OK
G__reallocate_null_buf (Begins at: 824 Ends at: 838)
LOC:          |      15 |       |      OK |
metrics are OK
G__reallocate_mask_buf (Begins at: 843 Ends at: 857)
LOC:          |      15 |       |      OK |
metrics are OK
G__reallocate_temp_buf (Begins at: 862 Ends at: 889)
LOC:          |      28 |       |      OK |
metrics are OK
G_set_fp_type (Begins at: 891 Ends at: 920)
LOC:          |      30 |       |      OK |
metrics are OK
G_raster_map_is_fp (Begins at: 922 Ends at: 954)
CalledNBR:    |       7 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
G_raster_map_type (Begins at: 956 Ends at: 986)
CalledNBR:    |       8 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
G_raster_map_type2 (Begins at: 988 Ends at: 1006)
LOC:          |      19 |       |      OK |
metrics are OK
G__check_fp_type (Begins at: 1010 Ends at: 1065)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
G_open_raster_new (Begins at: 1067 Ends at: 1083)
CalledNBR:    |       5 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_open_raster_new_uncompressed (Begins at: 1085 Ends at: 1114)
CalledNBR:    |       6 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_set_quant_rules (Begins at: 1116 Ends at: 1143)
Complexity:   |       5 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-26 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
