[GRASS-QA] GRASS QA: glynn | ./grass6/lib/init/mke_mapset.c |no clones | 0 monsters | 0 warnings
Fri Oct 27 19:30:43 EDT 2006
Hello glynn,
ANALYSIS
lib/init/mke_mapset.c functions
make_mapset (Begins at: 17 Ends at: 49)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-27 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
