[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.profile/ExtractProf.c |no clones | 1 monsters | 0 warnings
Sat Oct 28 17:01:23 EDT 2006
Hello glynn,
ANALYSIS
display/d.profile/ExtractProf.c functions
ExtractProfile (Begins at: 48 Ends at: 320)
Complexity:   |      33 |    ** | Warning |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |     273 |   *** | MONSTER |
1 metric are OUT OF RANGE!
ucat_max (Begins at: 322 Ends at: 345)
Complexity:   |      11 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
ucat_min (Begins at: 348 Ends at: 368)
Complexity:   |       8 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
