[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.what.rast/what.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 28 17:01:24 EDT 2006
Hello glynn,
ANALYSIS
display/d.what.rast/what.c functions
what (Begins at: 8 Ends at: 88)
Complexity: | 11 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 29 | | OK |
LOC: | 81 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
