[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.rast.num/number.c |no clones | 1 monsters | 0 warnings
Sat Oct 28 17:01:24 EDT 2006
Hello glynn,
ANALYSIS
display/d.rast.num/number.c functions
main (Begins at: 53 Ends at: 311)
Complexity:   |      21 |     * |         |
CalledNBR:    |      92 |   *** | MONSTER |
LOC:          |     259 |    ** | Warning |
1 metric are OUT OF RANGE!
draw_number (Begins at: 315 Ends at: 363)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
