[GRASS-QA] GRASS QA: glynn | ./grass6/ps/ps.map/outl_io.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 28 17:01:24 EDT 2006
Hello glynn,
ANALYSIS
ps/ps.map/outl_io.c functions
o_io_init (Begins at: 17 Ends at: 24)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
o_read_row (Begins at: 26 Ends at: 57)
Complexity: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 32 | | OK |
metrics are OK
blank_line (Begins at: 59 Ends at: 64)
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
o_open_file (Begins at: 66 Ends at: 90)
Complexity: | 3 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 25 | | OK |
metrics are OK
o_close_file (Begins at: 92 Ends at: 97)
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
