[GRASS-QA] GRASS QA: glynn | ./grass6/ps/ps.map/ps_raster.c |no clones | 0 monsters | 0 warnings
Sat Oct 28 17:01:24 EDT 2006
Hello glynn,
ANALYSIS
ps/ps.map/ps_raster.c functions
PS_make_mask (Begins at: 23 Ends at: 64)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
PS_raster_plot (Begins at: 66 Ends at: 223)
Complexity:   |      20 |     * |         |
CalledNBR:    |      42 |     * |         |
LOC:          |     158 |     * |         |
metrics are OK
ps_write_mask_row (Begins at: 226 Ends at: 266)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-28 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
