[GRASS-QA] GRASS QA: glynn | ./grass6/raster3d/r3.cross.rast/main.c
|no clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Oct 28 17:01:24 EDT 2006
Hello glynn,
ANALYSIS
raster3d/r3.cross.rast/main.c functions
fatal_error (Begins at: 48 Ends at: 68)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 21 | | OK |
metrics are OK
close_output_map (Begins at: 74 Ends at: 78)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 5 | | OK |
metrics are OK
set_params (Begins at: 84 Ends at: 111)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
rast3d_cross_section (Begins at: 118 Ends at: 247)
Complexity: | 23 | * | |
CalledNBR: | 30 | | OK |
LOC: | 130 | * | |
metrics are OK
main (Begins at: 253 Ends at: 402)
ParamNBR: | 2 | | OK |
CalledNBR: | 62 | ** | Warning |
LOC: | 150 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-28 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
