[GRASS-QA] GRASS QA: glynn | ./grass6/lib/init/mke_loc.c |no clones
| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Oct 29 20:02:25 EST 2006
Hello glynn,
ANALYSIS
lib/init/mke_loc.c functions
make_location (Begins at: 13 Ends at: 184)
Complexity: | 23 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 66 | ** | Warning |
LOC: | 172 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-10-29 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 85 |
LOC: 41 | 189 | 264 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
