[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.watershed/front/main.c |no clones | 2 monsters | 0 warnings
Sun Oct 29 22:03:08 EST 2006
Hello hamish,
ANALYSIS
raster/r.watershed/front/main.c functions
main (Begins at: 9 Ends at: 330)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |     119 |   *** | MONSTER |
LOC:          |     322 |   *** | MONSTER |
2 metric are OUT OF RANGE!
write_hist (Begins at: 333 Ends at: 349)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-29 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     264 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
