[GRASS-QA] GRASS QA: markus | ./grass6/gem/main.c |no clones | 3 monsters | 0 warnings
Tue Oct 31 14:39:34 EST 2006
Hello markus,
ANALYSIS
gem/main.c functions
show_help (Begins at: 146 Ends at: 182)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      35 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
show_details (Begins at: 185 Ends at: 202)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
show_license (Begins at: 205 Ends at: 221)
LOC:          |      17 |       |      OK |
metrics are OK
show_version (Begins at: 224 Ends at: 231)
CalledNBR:    |       6 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
get_configure_options (Begins at: 237 Ends at: 259)
Complexity:   |       4 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
main (Begins at: 262 Ends at: 775)
Complexity:   |      79 |   *** | MONSTER |
CalledNBR:    |     137 |   *** | MONSTER |
LOC:          |     514 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-31 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
