[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.resamp.interp/main.c |no clones | 2 monsters | 0 warnings
Tue Oct 31 17:45:30 EST 2006
Hello glynn,
ANALYSIS
raster/r.resamp.interp/main.c functions
read_rows (Begins at: 11 Ends at: 39)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
main (Begins at: 41 Ends at: 332)
Complexity:   |      17 |     * |         |
CalledNBR:    |     119 |   *** | MONSTER |
LOC:          |     292 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-10-31 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      85 |
LOC:                    41 |       189 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
