[GRASS-QA] GRASS QA: markus | ./grass6/lib/raster/parse_ftcap.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 1 06:10:36 EDT 2006
Hello markus,
ANALYSIS
lib/raster/parse_ftcap.c functions
R_parse_freetypecap (Begins at: 8 Ends at: 63)
Complexity: | 10 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 56 | | OK |
metrics are OK
R_free_freetypecap (Begins at: 65 Ends at: 81)
Complexity: | 2 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 17 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
