[GRASS-QA] GRASS QA: markus | ./grass6/lib/raster/loc_proto.c |6
clones ( loc_proto.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 1 06:10:36 EDT 2006
Hello markus,
ANALYSIS
lib/raster/loc_proto.c functions
LOC_screen_left (Begins at: 27 Ends at: 43)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 17 | | OK |
metrics are OK
LOC_screen_rite (Begins at: 45 Ends at: 61)
LOC: | 17 | | OK |
metrics are OK
LOC_screen_bot (Begins at: 63 Ends at: 80)
LOC: | 18 | | OK |
metrics are OK
LOC_screen_top (Begins at: 82 Ends at: 89)
LOC: | 8 | | OK |
metrics are OK
LOC_get_num_colors (Begins at: 91 Ends at: 109)
LOC: | 19 | | OK |
metrics are OK
LOC_color_table_float (Begins at: 111 Ends at: 127)
LOC: | 17 | | OK |
metrics are OK
LOC_color_table_fixed (Begins at: 129 Ends at: 132)
LOC: | 4 | | OK |
metrics are OK
LOC_color_offset (Begins at: 134 Ends at: 149)
LOC: | 16 | | OK |
metrics are OK
LOC_color (Begins at: 151 Ends at: 168)
LOC: | 18 | | OK |
metrics are OK
LOC_standard_color (Begins at: 170 Ends at: 189)
LOC: | 20 | | OK |
metrics are OK
LOC_RGB_color (Begins at: 191 Ends at: 209)
ParamNBR: | 3 | | OK |
LOC: | 19 | | OK |
metrics are OK
LOC_reset_color (Begins at: 211 Ends at: 235)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 25 | | OK |
metrics are OK
LOC_reset_colors (Begins at: 237 Ends at: 252)
ParamNBR: | 5 | * | |
LOC: | 16 | | OK |
metrics are OK
LOC_line_width (Begins at: 254 Ends at: 268)
LOC: | 15 | | OK |
metrics are OK
LOC_erase (Begins at: 270 Ends at: 286)
LOC: | 17 | | OK |
metrics are OK
LOC_move_abs (Begins at: 288 Ends at: 308)
ParamNBR: | 2 | | OK |
LOC: | 21 | | OK |
metrics are OK
LOC_move_rel (Begins at: 310 Ends at: 327)
LOC: | 18 | | OK |
metrics are OK
LOC_cont_abs (Begins at: 329 Ends at: 351)
LOC: | 23 | | OK |
metrics are OK
LOC_cont_rel (Begins at: 353 Ends at: 371)
LOC: | 19 | | OK |
metrics are OK
LOC_polydots_abs (Begins at: 373 Ends at: 393)
LOC: | 21 | | OK |
metrics are OK
LOC_polydots_rel (Begins at: 395 Ends at: 416)
LOC: | 22 | | OK |
metrics are OK
LOC_polyline_abs (Begins at: 418 Ends at: 440)
LOC: | 23 | | OK |
metrics are OK
LOC_polyline_rel (Begins at: 442 Ends at: 460)
LOC: | 19 | | OK |
metrics are OK
LOC_polygon_abs (Begins at: 462 Ends at: 482)
LOC: | 21 | | OK |
metrics are OK
LOC_polygon_rel (Begins at: 484 Ends at: 503)
LOC: | 20 | | OK |
metrics are OK
LOC_box_abs (Begins at: 505 Ends at: 523)
LOC: | 19 | | OK |
metrics are OK
LOC_box_rel (Begins at: 525 Ends at: 540)
LOC: | 16 | | OK |
metrics are OK
LOC_text_size (Begins at: 542 Ends at: 547)
LOC: | 6 | | OK |
metrics are OK
LOC_text_rotation (Begins at: 549 Ends at: 567)
LOC: | 19 | | OK |
metrics are OK
LOC_set_window (Begins at: 569 Ends at: 584)
LOC: | 16 | | OK |
metrics are OK
LOC_text (Begins at: 586 Ends at: 608)
LOC: | 23 | | OK |
metrics are OK
LOC_get_text_box (Begins at: 610 Ends at: 615)
LOC: | 6 | | OK |
metrics are OK
select_font (Begins at: 617 Ends at: 676)
Complexity: | 3 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 60 | | OK |
metrics are OK
LOC_font (Begins at: 678 Ends at: 684)
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
LOC_font_freetype (Begins at: 686 Ends at: 689)
LOC: | 4 | | OK |
metrics are OK
LOC_charset (Begins at: 691 Ends at: 694)
LOC: | 4 | | OK |
metrics are OK
LOC_font_freetype_release (Begins at: 696 Ends at: 699)
LOC: | 4 | | OK |
metrics are OK
LOC_panel_save (Begins at: 701 Ends at: 709)
CalledNBR: | 4 | | OK |
LOC: | 9 | | OK |
metrics are OK
LOC_panel_restore (Begins at: 711 Ends at: 717)
LOC: | 7 | | OK |
metrics are OK
LOC_panel_delete (Begins at: 719 Ends at: 743)
CalledNBR: | 3 | | OK |
LOC: | 25 | | OK |
metrics are OK
LOC_set_RGB_color (Begins at: 745 Ends at: 773)
LOC: | 29 | | OK |
metrics are OK
LOC_RGB_raster (Begins at: 775 Ends at: 813)
ParamNBR: | 6 | * | |
LOC: | 39 | | OK |
metrics are OK
LOC_raster_char (Begins at: 815 Ends at: 820)
LOC: | 6 | | OK |
metrics are OK
LOC_raster_int (Begins at: 822 Ends at: 827)
LOC: | 6 | | OK |
metrics are OK
LOC_bitmap (Begins at: 829 Ends at: 834)
LOC: | 6 | | OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
LOC_text_rotation LOC_get_num_colors LOC_polyline_abs LOC_polydots_rel LOC_screen_rite LOC_screen_left
In lib/raster/loc_proto.c clones of LOC_polyline_abs are:
lib/gis/cats.c G_mark_f_raster_cats
lib/gis/cats.c G_mark_c_raster_cats
In lib/raster/loc_proto.c clones of LOC_polydots_rel are:
lib/gis/cats.c G_init_cats
In lib/raster/loc_proto.c clones of LOC_text_rotation are:
lib/raster/loc_proto.c LOC_get_num_colors
In lib/raster/loc_proto.c clones of LOC_screen_rite are:
lib/raster/loc_proto.c LOC_screen_left
In lib/raster/loc_proto.c clones of LOC_screen_left are:
lib/raster/loc_proto.c LOC_screen_rite
In lib/raster/loc_proto.c clones of LOC_get_num_colors are:
lib/raster/loc_proto.c LOC_text_rotation
Threshold GRASS6 key metrics values at 2006-09-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
