[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Get_t_box.c |1
clones ( Get_t_box.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 1 14:36:59 EDT 2006
Hello glynn,
ANALYSIS
lib/driver/Get_t_box.c functions
COM_Get_text_box (Begins at: 4 Ends at: 18)
Complexity: | 2 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 5 | | OK |
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
COM_Get_text_box
In lib/driver/Get_t_box.c clones of COM_Get_text_box are:
display/drivers/lib/Get_t_box.c COM_Get_text_box
Threshold GRASS6 key metrics values at 2006-09-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
