[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/Text.c |1 clones ( Get_t_box.c Text.c )| 0 monsters | 0 warnings
Fri Sep 1 14:37:00 EDT 2006
Hello glynn,
ANALYSIS
lib/driver/Text.c functions
COM_Text (Begins at: 4 Ends at: 11)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  COM_Text
In lib/driver/Text.c clones of  COM_Text are:
	display/drivers/lib/Text.c  COM_Text
Threshold GRASS6 key metrics values at 2006-09-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
