[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/common.c |4 clones ( common.c )| 0 monsters | 0 warnings
Fri Sep 1 19:28:39 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/common.c functions
R_flush (Begins at: 17 Ends at: 20)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
R_set_update_function (Begins at: 31 Ends at: 42)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
R_call_update_function (Begins at: 44 Ends at: 48)
Complexity:   |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
R_has_update_function (Begins at: 56 Ends at: 59)
LOC:          |       4 |       |      OK |
metrics are OK
R_set_cancel (Begins at: 70 Ends at: 73)
LOC:          |       4 |       |      OK |
metrics are OK
R_get_cancel (Begins at: 81 Ends at: 101)
LOC:          |      21 |       |      OK |
metrics are OK
R_raster (Begins at: 103 Ends at: 133)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
R_pad_perror (Begins at: 135 Ends at: 152)
Complexity:   |      10 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
R_pad_freelist (Begins at: 154 Ends at: 165)
CalledNBR:    |       2 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  R_get_cancel  R_raster  R_set_update_function  R_pad_perror
In lib/raster/common.c clones of  R_pad_perror are:
	lib/raster/pad.c  R_pad_perror
In lib/raster/common.c clones of  R_raster are:
	lib/raster/commands.c  R_raster
In lib/raster/common.c clones of  R_get_cancel are:
	lib/raster/commands.c  R_get_cancel
In lib/raster/common.c clones of  R_set_update_function are:
	lib/raster/commands.c  R_set_update_function
Threshold GRASS6 key metrics values at 2006-09-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
