[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_proto.c |2
clones ( common.c com_proto.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Fri Sep 1 19:28:39 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/com_proto.c functions
R_screen_left (Begins at: 24 Ends at: 36)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 13 | | OK |
metrics are OK
R_screen_rite (Begins at: 38 Ends at: 50)
LOC: | 13 | | OK |
metrics are OK
R_screen_bot (Begins at: 52 Ends at: 65)
LOC: | 14 | | OK |
metrics are OK
R_screen_top (Begins at: 67 Ends at: 70)
LOC: | 4 | | OK |
metrics are OK
R_get_num_colors (Begins at: 72 Ends at: 88)
LOC: | 17 | | OK |
metrics are OK
R_color_table_float (Begins at: 90 Ends at: 106)
LOC: | 17 | | OK |
metrics are OK
R_color_table_fixed (Begins at: 108 Ends at: 111)
LOC: | 4 | | OK |
metrics are OK
R_color_offset (Begins at: 113 Ends at: 126)
LOC: | 14 | | OK |
metrics are OK
R_color (Begins at: 128 Ends at: 143)
LOC: | 16 | | OK |
metrics are OK
R_standard_color (Begins at: 145 Ends at: 162)
LOC: | 18 | | OK |
metrics are OK
R_RGB_color (Begins at: 164 Ends at: 180)
ParamNBR: | 3 | | OK |
LOC: | 17 | | OK |
metrics are OK
R_reset_color (Begins at: 182 Ends at: 201)
ParamNBR: | 4 | | OK |
LOC: | 20 | | OK |
metrics are OK
R_reset_colors (Begins at: 203 Ends at: 216)
ParamNBR: | 5 | * | |
LOC: | 14 | | OK |
metrics are OK
R_line_width (Begins at: 218 Ends at: 230)
LOC: | 13 | | OK |
metrics are OK
R_erase (Begins at: 232 Ends at: 246)
LOC: | 15 | | OK |
metrics are OK
R_move_abs (Begins at: 248 Ends at: 266)
ParamNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
R_move_rel (Begins at: 268 Ends at: 283)
LOC: | 16 | | OK |
metrics are OK
R_cont_abs (Begins at: 285 Ends at: 305)
LOC: | 21 | | OK |
metrics are OK
R_cont_rel (Begins at: 307 Ends at: 323)
LOC: | 17 | | OK |
metrics are OK
R_polydots_abs (Begins at: 325 Ends at: 343)
LOC: | 19 | | OK |
metrics are OK
R_polydots_rel (Begins at: 345 Ends at: 364)
LOC: | 20 | | OK |
metrics are OK
R_polyline_abs (Begins at: 366 Ends at: 386)
LOC: | 21 | | OK |
metrics are OK
R_polyline_rel (Begins at: 388 Ends at: 404)
LOC: | 17 | | OK |
metrics are OK
R_polygon_abs (Begins at: 406 Ends at: 424)
LOC: | 19 | | OK |
metrics are OK
R_polygon_rel (Begins at: 426 Ends at: 443)
LOC: | 18 | | OK |
metrics are OK
R_box_abs (Begins at: 445 Ends at: 461)
LOC: | 17 | | OK |
metrics are OK
R_box_rel (Begins at: 463 Ends at: 476)
LOC: | 14 | | OK |
metrics are OK
R_text_size (Begins at: 478 Ends at: 481)
LOC: | 4 | | OK |
metrics are OK
R_text_rotation (Begins at: 483 Ends at: 499)
LOC: | 17 | | OK |
metrics are OK
R_set_window (Begins at: 501 Ends at: 514)
LOC: | 14 | | OK |
metrics are OK
R_text (Begins at: 516 Ends at: 536)
LOC: | 21 | | OK |
metrics are OK
R_get_text_box (Begins at: 538 Ends at: 573)
LOC: | 36 | | OK |
metrics are OK
R_font (Begins at: 575 Ends at: 578)
LOC: | 4 | | OK |
metrics are OK
R_font_freetype (Begins at: 580 Ends at: 583)
LOC: | 4 | | OK |
metrics are OK
R_charset (Begins at: 585 Ends at: 588)
LOC: | 4 | | OK |
metrics are OK
R_font_freetype_release (Begins at: 590 Ends at: 593)
LOC: | 4 | | OK |
metrics are OK
R_panel_save (Begins at: 595 Ends at: 598)
LOC: | 4 | | OK |
metrics are OK
R_panel_restore (Begins at: 600 Ends at: 603)
LOC: | 4 | | OK |
metrics are OK
R_panel_delete (Begins at: 605 Ends at: 624)
LOC: | 20 | | OK |
metrics are OK
R_set_RGB_color (Begins at: 626 Ends at: 652)
LOC: | 27 | | OK |
metrics are OK
R_RGB_raster (Begins at: 654 Ends at: 690)
ParamNBR: | 6 | * | |
LOC: | 37 | | OK |
metrics are OK
R_raster_char (Begins at: 692 Ends at: 695)
LOC: | 4 | | OK |
metrics are OK
R_raster_int (Begins at: 697 Ends at: 700)
LOC: | 4 | | OK |
metrics are OK
R_bitmap (Begins at: 702 Ends at: 705)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
R_polyline_rel R_polydots_rel
In lib/raster/com_proto.c clones of R_polydots_rel are:
In lib/raster/com_proto.c clones of R_polyline_rel are:
lib/gis/get_row.c G_get_map_row_nomask
Threshold GRASS6 key metrics values at 2006-09-01 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
