[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/rem_get.c |no clones | 0 monsters | 0 warnings
Fri Sep 1 19:28:39 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/rem_get.c functions
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
