[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/loc_proto.c |6 clones ( common.c com_proto.c loc_proto.c )| 0 monsters | 0 warnings
Fri Sep 1 19:28:39 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/loc_proto.c functions
LOC_screen_left (Begins at: 25 Ends at: 41)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
LOC_screen_rite (Begins at: 43 Ends at: 59)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_screen_bot (Begins at: 61 Ends at: 78)
LOC:          |      18 |       |      OK |
metrics are OK
LOC_screen_top (Begins at: 80 Ends at: 87)
LOC:          |       8 |       |      OK |
metrics are OK
LOC_get_num_colors (Begins at: 89 Ends at: 105)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_color_table_float (Begins at: 107 Ends at: 123)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_color_table_fixed (Begins at: 125 Ends at: 128)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_color_offset (Begins at: 130 Ends at: 143)
LOC:          |      14 |       |      OK |
metrics are OK
LOC_color (Begins at: 145 Ends at: 160)
LOC:          |      16 |       |      OK |
metrics are OK
LOC_standard_color (Begins at: 162 Ends at: 179)
LOC:          |      18 |       |      OK |
metrics are OK
LOC_RGB_color (Begins at: 181 Ends at: 197)
ParamNBR:     |       3 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
LOC_reset_color (Begins at: 199 Ends at: 221)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
LOC_reset_colors (Begins at: 223 Ends at: 236)
ParamNBR:     |       5 |     * |         |
LOC:          |      14 |       |      OK |
metrics are OK
LOC_line_width (Begins at: 238 Ends at: 250)
LOC:          |      13 |       |      OK |
metrics are OK
LOC_erase (Begins at: 252 Ends at: 266)
LOC:          |      15 |       |      OK |
metrics are OK
LOC_move_abs (Begins at: 268 Ends at: 286)
LOC:          |      19 |       |      OK |
metrics are OK
LOC_move_rel (Begins at: 288 Ends at: 303)
LOC:          |      16 |       |      OK |
metrics are OK
LOC_cont_abs (Begins at: 305 Ends at: 325)
LOC:          |      21 |       |      OK |
metrics are OK
LOC_cont_rel (Begins at: 327 Ends at: 343)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_polydots_abs (Begins at: 345 Ends at: 363)
LOC:          |      19 |       |      OK |
metrics are OK
LOC_polydots_rel (Begins at: 365 Ends at: 384)
LOC:          |      20 |       |      OK |
metrics are OK
LOC_polyline_abs (Begins at: 386 Ends at: 406)
LOC:          |      21 |       |      OK |
metrics are OK
LOC_polyline_rel (Begins at: 408 Ends at: 424)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_polygon_abs (Begins at: 426 Ends at: 444)
LOC:          |      19 |       |      OK |
metrics are OK
LOC_polygon_rel (Begins at: 446 Ends at: 463)
LOC:          |      18 |       |      OK |
metrics are OK
LOC_box_abs (Begins at: 465 Ends at: 481)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_box_rel (Begins at: 483 Ends at: 496)
LOC:          |      14 |       |      OK |
metrics are OK
LOC_text_size (Begins at: 498 Ends at: 501)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_text_rotation (Begins at: 503 Ends at: 519)
LOC:          |      17 |       |      OK |
metrics are OK
LOC_set_window (Begins at: 521 Ends at: 534)
LOC:          |      14 |       |      OK |
metrics are OK
LOC_text (Begins at: 536 Ends at: 556)
LOC:          |      21 |       |      OK |
metrics are OK
LOC_get_text_box (Begins at: 558 Ends at: 593)
LOC:          |      36 |       |      OK |
metrics are OK
LOC_font (Begins at: 595 Ends at: 598)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_font_freetype (Begins at: 600 Ends at: 603)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_charset (Begins at: 605 Ends at: 608)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_font_freetype_release (Begins at: 610 Ends at: 613)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_panel_save (Begins at: 615 Ends at: 621)
CalledNBR:    |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
LOC_panel_restore (Begins at: 623 Ends at: 627)
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
LOC_panel_delete (Begins at: 629 Ends at: 651)
CalledNBR:    |       3 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
LOC_set_RGB_color (Begins at: 653 Ends at: 679)
LOC:          |      27 |       |      OK |
metrics are OK
LOC_RGB_raster (Begins at: 681 Ends at: 717)
ParamNBR:     |       6 |     * |         |
LOC:          |      37 |       |      OK |
metrics are OK
LOC_raster_char (Begins at: 719 Ends at: 722)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_raster_int (Begins at: 724 Ends at: 727)
LOC:          |       4 |       |      OK |
metrics are OK
LOC_bitmap (Begins at: 729 Ends at: 732)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
  LOC_text_rotation  LOC_get_num_colors  LOC_polyline_abs  LOC_polydots_rel  LOC_screen_rite  LOC_screen_left
In lib/raster/loc_proto.c clones of  LOC_polyline_abs are:
	lib/gis/cats.c  G_mark_f_raster_cats
	lib/gis/cats.c  G_mark_c_raster_cats
In lib/raster/loc_proto.c clones of  LOC_polydots_rel are:
	lib/gis/cats.c  G_init_cats
In lib/raster/loc_proto.c clones of  LOC_text_rotation are:
	lib/raster/loc_proto.c  LOC_get_num_colors
In lib/raster/loc_proto.c clones of  LOC_screen_rite are:
	lib/raster/loc_proto.c  LOC_screen_left
In lib/raster/loc_proto.c clones of  LOC_screen_left are:
	lib/raster/loc_proto.c  LOC_screen_rite
In lib/raster/loc_proto.c clones of  LOC_get_num_colors are:
	lib/raster/loc_proto.c  LOC_text_rotation
Threshold GRASS6 key metrics values at 2006-09-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
