[GRASS-QA] GRASS QA: markus | ./grass6/lib/vector/Vlib/init_head.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Sep 5 18:40:51 EDT 2006
Hello markus,
ANALYSIS
lib/vector/Vlib/init_head.c functions
Vect__init_head (Begins at: 30 Ends at: 58)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 29 | | OK |
metrics are OK
Vect_copy_head_data (Begins at: 67 Ends at: 81)
ParamNBR: | 2 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-09-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
