[GRASS-QA] GRASS QA: markus | ./grass6/lib/vector/Vlib/init_head.c |no clones | 0 monsters | 0 warnings
Tue Sep 5 18:48:03 EDT 2006
Hello markus,
ANALYSIS
lib/vector/Vlib/init_head.c functions
Vect__init_head (Begins at: 30 Ends at: 58)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Vect_copy_head_data (Begins at: 67 Ends at: 81)
CalledNBR:    |      18 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
