[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.carve/lobf.c |no clones | 0 monsters | 0 warnings
Wed Sep 13 09:53:39 EDT 2006
Hello brad,
ANALYSIS
raster/r.carve/lobf.c functions
pg_init (Begins at: 30 Ends at: 34)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
pg_y_from_x (Begins at: 40 Ends at: 43)
LOC:          |       4 |       |      OK |
metrics are OK
pg_addpt (Begins at: 49 Ends at: 87)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
pg_getpoints (Begins at: 93 Ends at: 96)
LOC:          |       4 |       |      OK |
metrics are OK
pg_getpoints_reversed (Begins at: 102 Ends at: 119)
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-13 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
