[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.carve/enforce_ds.c |no clones | 0 monsters | 1 warnings
Wed Sep 13 09:53:39 EDT 2006
Hello brad,
ANALYSIS
raster/r.carve/enforce_ds.c functions
enforce_downstream (Begins at: 53 Ends at: 92)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      40 |       |      OK |
metrics are OK
process_line (Begins at: 95 Ends at: 207)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      32 |       |      OK |
LOC:          |     113 |     * |         |
metrics are OK
clear_bitmap (Begins at: 210 Ends at: 217)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
traverse_line_flat (Begins at: 220 Ends at: 243)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
traverse_line_noflat (Begins at: 246 Ends at: 270)
ParamNBR:     |       4 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
set_min_point (Begins at: 274 Ends at: 300)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       9 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
lowest_cell_near_point (Begins at: 304 Ends at: 421)
Complexity:   |      25 |     * |         |
CalledNBR:    |      22 |       |      OK |
LOC:          |     118 |     * |         |
metrics are OK
process_line_segment (Begins at: 429 Ends at: 519)
ParamNBR:     |       7 |    ** | Warning |
LOC:          |      91 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-13 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
