[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.describe/tree.c |no clones | 0 monsters | 0 warnings
Fri Sep 15 04:46:52 EDT 2006
Hello brad,
ANALYSIS
raster/r.describe/tree.c functions
plant_tree (Begins at: 38 Ends at: 48)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
add_node_to_tree (Begins at: 51 Ends at: 122)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
first_node (Begins at: 130 Ends at: 140)
CalledNBR:    |       0 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
next_node (Begins at: 143 Ends at: 163)
Complexity:   |       4 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-09-15 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
